This will cut down on confusion (one place to do updates), and also makes it easier for us to facilitate updating clones ( something we’ve been talking about publicly since at least the first Level Up ).
You go to Exchange to get new modules to install.
You go to Toolbox to manage/create/edit/delete modules you already have installed.
Yes, these were in the same place in v3, but we made the call to separate them in v4.
I like the idea of including the pre-saved filters for standard queries (update, deprecated, new, etc), it’s just not at the top of the list with the other fixes and fit and finish stuff. Certainly something we can consider adding in 2024.
I’m not aware of any 4-hourly check on DataSources. We’re doing a daily index of the “in use/not in use” data (which is more advanced than running AT like v3, we actually check for instances now).
Yes, we did debut the new capabilities, but we haven’t removed the old ones yet. Even in a hypothetical world where software came out perfect on the first iteration, I would hesitant to hit you with a new experience with zero overlap.
Related Content
- 14 days agoStuart_Weenig
- 2 years agocamillebushn
- 4 years agoVitor_Santos
