Hi Victor, thanks for the feedback.
Update from my side:
I have managed to reach out to Silverpeak in the backend with the feedback below. I still need to read and understand this fully but it suggests that stats are to be pulled from the Orchestrator itself and not from the appliances.
"To get the tunnel stats, you can use REST API from orchestrator--> Support--> rest API.
You can search for aggregate stats and use below API where nePK is the appliance ID. You can find this when you hover your mouse over the appliance name in the orchestrator list view on left hand side.
GET /stats/aggregate/tunnel/{nePk}"
I can only pick htis up again later next week so please go ahead and log it if its urgent on your side. If there is any feedback, please update here and I will do the same.
Regards,
Kris
