11 months ago
DataSource recording zeroes for non-zero raw responses
I wrote a DataSource that is exhibiting a weird problem. Most of the data points are recording zeroes, but when I click "Poll Now", I see non-zero values in the Raw Response. The DataSource uses multi-line key=value pairs.
I'm not sure how to troubleshoot this. Has anyone seen this before?
Here is a screenshot to illustrate my issue:
Hi Mark,
You probably need to use metric type Gauge instead of Derive. Have you tried that ?
Doc: https://www.logicmonitor.com/support/logicmodules/datasources/datapoints/normal-datapoints
