- phakesley
Neophyte
- phakesley
Neophyte
Hi I have this xml file provided by LM. I have not as yet tried it but it might help you. Rename to .xml
- Justin_Lanoue
Advisor
I don't see an attached document, but LM Support also provided me a very old dev DataSource that used a deprecated API version.
The script was a good base as I was able to rework it to use a Bearer Token instead and pull data I wanted.
I can publish it if there is interest but it's still a WIP.- thethird78
Neophyte
I would be very interested in seeing it. Are you publishing it here or the LogicModule exchange?
