5 years agoI think there's a way that you can initiate the execution of a report then fetch the data from that report, but that probably couldn't be combined into a single api call.
There's also a way to fetch the data for a dashboard widget. You'd still have to do one call per dashboard widget though.
What are you trying to accomplish? Depending on what you're trying to do, there may be more elegant solutions than API interaction.
