Vitor_Santos
Expert
5 years ago3 minutes ago, Stuart Weenig said:I don't know of a way, but you might ping support. There used to be a bunch of freeware tools that do this.
Yes, I found a tool this morning that does that. Was able to create a config source that accommodates our needs, however, that represent a LOT of manual work in each collector. Which isn't a optimal solution.
We were wondering if there's a property that we can set on the collector config for it to dump the received traps within a certain log file. I'll poke support about it.
Thanks anyway @Stuart Weenig!
