- 18 hours ago, Stuart Weenig said:
The 'store procedure' comment got me thinking. A standard way of getting data into LM using Groovy is by using our SQL library to run a SQL query. If you can use the store procedure to log those events in SQL and get at the event list through a simple SQL query, that might be the easiest option. Here's an example of running a SQL query through Groovy.
Thanks for your advise . If anyone has already implemented it ?
- Anonymous
- 22 minutes ago, Stuart Weenig said:
If you haven't already found something in the Exchange, you're probably looking at building your own EventSource. I say EventSource because these appear to be alerts, not numerical data. So, you'd start by first asking how that data can be got at programmatically. Then you'd write a script to fetch that data. That script can be run natively with Groovy or you could use a different programming language. (Using a different programming language simply requires that that language's interpreter be available to the collector. The collector can't run a Python script if Python is not installed on the same server as the collector.)
I'm not a SQL guy, but SSMS seems like a message queue yeah? If so, can you script a way to get the stuff you want out of that message queue? That's your first hurdle.
Hi Stuart thanks for your reply . SSMS is SQL server managment Studio . These alerts can be create using this or you can use the store procedure. You can put the Error number here and then enabler the alert . I'll try above option . More suggestion are welcome :)/emoticons/smile@2x.png 2x" title=":)" width="20" />
- Anonymous
