- Patrick_Rouse
Product Manager
@Patrick Rouse - the original statement mentioned MT Sensors (e.g. Meraki MT10 Temperature and Humidity Sensors) - is this something that will be supported by a LogicModule? Sensor support doesn’t appear to be documented (as at 07 Dec 2023) per https://www.logicmonitor.com/support/cisco-meraki-monitoring#h-logicmodules-in-packageThese modules are now generally available.
- Patrick_Rouse
Product Manager
We plan to release the first iteration of MT Sensor monitoring modules in the next 1-2 weeks.
- Patrick_Rouse
Product Manager
MT-series sensors are next on my list of Meraki devices to support, and I anticipate bringing this functionality to market in the first half of 2024. If you’re interested in participating in the R&D as an early access tester, please email me at first dot last at logicmonitor.com.
In addition to on our website, our current Meraki monitoring features are listed/shown here:
https://apps.meraki.io/en-US/apps/420402/logicmonitor-%7C-lm-envision#features @Patrick Rouse - the original statement mentioned MT Sensors (e.g. Meraki MT10 Temperature and Humidity Sensors) - is this something that will be supported by a LogicModule? Sensor support doesn’t appear to be documented (as at 07 Dec 2023) per https://www.logicmonitor.com/support/cisco-meraki-monitoring#h-logicmodules-in-package- Patrick_Rouse
Product Manager
Modules for monitoring Meraki MG Cellular Gateways are now generally available. They monitor both signal power (RSRP) and signal quality (RSRQ), reachability, and include (in v197) a new Cellular Gateway topology map graphic.
Related Content
- 6 years ago
- 5 years ago
