Lewis_Beard
Professor
3 years agoLogicmonitor_sdk filters are driving me insane. Please help?
So I've been trying to use the logicmonitor_sdk and it seems pretty good, but I keep getting stumped by the (in my opinion) completely barren documentation, at least thats how I view it.
In p...
- Anonymous3 years ago
How about this?
from lm import lm # details on how to use this here: https://communities.logicmonitor.com/topic/7713-lm-wrapper-for-the-python-sdk/ #replace with the global datasource id from which you want instances listed ds_global_id = 53 # get the device list devices = {device.name:device.to_dict() for device in lm.get_device_list(size=1000).items} # loop through each device for k,device in devices.items(): # get the list of datasources for the current device (this has to be done for every device, ug...) datasources = lm.get_device_datasource_list(device['id'],size=1000).items #create a new entry under each device to contain the datasources for that device device['datasources'] = [ # let that entry only contain the information we need, global ds id, local ds id, ds name, and isntance count {"global_ds_id": ds.data_source_id,"name": ds.data_source_name,"local_ds_id": ds.id,"instance_number": ds.instance_number} for ds in datasources # only include datasources that actually have instances if ds.instance_number > 0 and ds.data_source_id == ds_global_id ] # loop through each datasource on the device that has instances for ds in device['datasources']: # call for the list of instances and store as a new entry on this datasource ds['instances'] = lm.get_device_datasource_instance_list(device_id=device['id'], hds_id=ds['local_ds_id']).items for device,v in devices.items(): #for each device for ds in v['datasources']: # for each datasource that has non-zero count of instances on the device for instance in ds['instances']: # for each instance in the non-zero count datasource print(f"{device},{ds['name']},{instance.name}")
