- Kwame_A
LM Conqueror
Looks like utilizing our REST API is the best option for this.
Our Professional Services team can be commissioned to help create a custom scripted solution for this task. If you are interested, you can reach out to the Customer Success Manager for your account to discuss that option.
- Vaisu86
Neophyte
undefined - Anonymous
Yeah, you're gonna have to put/patch a ton of stuff using custom scripting from scratch.
- Kwame_A
LM Conqueror
Hello, Vaisu86 ,
From what I know, I don't believe there is an import/export for Settings, Custom properties, and other portal configurations like that. The best option that I know of would be to utilize the API but that could be a lofty task depending on the amount of items to copy over.
I will inquire internally if there are other options.
