Kwame_A
LM Conqueror
2 years agoHello, Vaisu86 ,
From what I know, I don't believe there is an import/export for Settings, Custom properties, and other portal configurations like that. The best option that I know of would be to utilize the API but that could be a lofty task depending on the amount of items to copy over.
I will inquire internally if there are other options.
