4 years agoI'd focus on whether or not you need all that in the wildvalue/wildalias to uniquely identify the instance. Wildvalue/wildalias should only contain the minimum necessary to uniquely identify the instance. If you just want that information visible, consider moving it to the description of the instance instead (or instance level properties).
