maxwellpinna's avatar
maxwellpinna
9 months ago
Help with .. "is schedule down" notice.
Recently a user created an SDT on a resource to intentionally do some maintenance on it. LogicMonitor emailed us an alert that the resource: The host <hostname> (<ip address>) is scheduled down fro...
  • Mike_Moniz's avatar
    9 months ago
    I believe there is an option in the Alert rules for "Send status notification for Acknowledge or SDT" which you can switch off to stop that.
