Of course, if you're getting results, that's good. I think it would be to your advantage to try for some of that "elegance". If you want to leave it alone, just let me know and I'll drop it.
Otherwise, let's talk about what data you're gathering and how we might make things easier for you in the long run. Generally, what do the different payloads represent? Different functions on the target device? Different micro-services? Different hardware components? Multiple instances of the same thing, just with different names/purposes/responses? The answers to these questions will help drive toward which elegance, if any, we can build into your solution.
Either way, it might help you to take a look at our eLearning around building DataSources. Getting to the eLearning requires that you first log into your LM portal and click the training link to establish your session. Then the link should work.
