5 years agoWhat you're looking for is alert trigger interval (and alert clear interval). Those aren't settings on the alert rule, but actually on the alert itself. Today, this is also a global setting, so use with care. These intervals specify how many additional poll cycles are required to be in violation (or in a cleared state) before the alert is opened (or cleared).
Since they are global settings, you have a few options on how to implement (it can be done non-globally, but you should approach it with your eyes open). Take a look and reply back if that's what you're looking for.
