Dominique
Advisor
5 years ago3 minutes ago, Stuart Weenig said:If you're making changes to the DS, you need to manually kick off discovery on the device to see the results right away (within a couple minutes).
Btw, adding auto.cert.days as a property is an alternative way of getting the data into a report (a resource inventory report).
For the auto.cert.days appears in the info but the calculation by "{($_.NotAfter - [datetime]::Today).Days}" remains as text not change as value !!!!
For the auto.cert.issuerby still not appearing in the info and as it was in before the "days" it might be an issue with the name ... uppercase/lowercase... syntax!!!
