Ad-hoc script running
Often when an alert pops up, I find myself running some very common troubleshooting/helpful tools to quickly gather more info. It would be nice to get that info quickly and easily without having to go to other tools when an alert occurs. For example - right now, when we get a high cpu alert the first thing I do is run pslist -s \\computername (PSTools are so awesome) and psloggedon \\computername to see who's logged in at the moment.
I know it's possible to create a datasource to discover all active processes, and retrieve CPU/memory/disk metrics specific to a given process, but processes on a given server might change pretty frequently so you'd have to run active discovery frequently. It just doesn't seem like the best way and most of the time I don't care what's running on the server and only need to know "in the moment."
A way to run a script via a button for a given datasource would be a really cool feature. Maybe on the datasource you could add a feature to hold a "gather additional data" or meta-data script, the script could then be invoked manually on an alert or datasource instance. IE when an alert occurs, you can click on a button in the alert called "gather additional data" or something which would run the script and produce a small box or window with the output. The ability to run periodically (every 15 seconds or 5 minutes, etc) would also be useful. This would also give a NOC the ability to troubleshoot a bit more or provide some additional context around an alert without everyone having to know a bunch of tools or have administrative access to a server.
