I need to filter a specific number of machines into a group or datasource. The filter is any machine that has the letter ‘c’ as the second-to-last character before the first period in a name. E.g. abc1.company.com.
I have some Regex that will do this ( [^.]*c[^.]\.[^.]*\.[^.] ), but when I try to use it in an AppliesTo it just fails.
According to this page: https://www.logicmonitor.com/support/terminology-syntax/scripting-support/what-is-lms I should be able to use =~ or !~ but they both give errors like this:
I tried putting it in quotes, parenthesis, quotes and parenthesis, and I couldn’t get it to work. I opened a ticket and they are going to look into it, but I thought I’d post here in case anyone knew if this is possible or not and how to make it work.
Best answer by Amr Abdelrahman
View original
