Azure Monitor metric namespaces
  • 25 May 2023
  • 1 reply
  • 62 views
Userlevel 1
Badge
We have a requirement to access metrics exposed in Azure Monitor under a different metric namespace (azure.vm.linux.guestmetrics). is it possible to extend the available namespace in anyway, or would I have to use a script collector to hit the azure monitor API?
icon
Best answer by tswisdom 30 May 2023, 21:24
View original
1 reply
Userlevel 4
Badge +4
Good afternoon @rthomasgww,
As of this moment, it isn’t possible to specify an alternate metric namespace with the core Azure modules, you would have to leverage a custom script in this scenario. Investigating the matter, it would seem we’d evaluated the viability of doing so previously and found it would would take a considerable amount of work while very few customers had any need or benefit. With that said, I would recommend submitting feedback through your portal to formally request support for this functionality.
Warm regards,
Tyler Wisdom
Reply
