3 years ago
Azure Monitor metric namespaces
We have a requirement to access metrics exposed in Azure Monitor under a different metric namespace (azure.vm.linux.guestmetrics). is it possible to extend the available namespace in anyway, or would...
- 3 years ago
Good afternoon
@rthomasgww ,
As of this moment, it isnβt possible to specify an alternate metric namespace with the core Azure modules, you would have to leverage a custom script in this scenario. Investigating the matter, it would seem weβd evaluated the viability of doing so previously and found it would would take a considerable amount of work while very few customers had any need or benefit. With that said, I would recommend submitting feedback through your portal to formally request support for this functionality.
Warm regards,
Tyler Wisdom
