lucjad
Neophyte
2 years agoI clicked on the J Drive and it says Filtered Out Messages of Capacity Greater Than 0. This Drive's Volume was monitored for months and now it's just not there.
2 years agoIs there any reason WMI would think that the drive has 0 capacity?
- lucjad2 years ago
Neophyte
Not sure. There were no recent changes to the host or Logic Monitor's configurations. What else can I check? This also happened to other server being monitored in LM.
- Anonymous2 years ago
Hm, try running:
Get-WmiObject -Class Win32_Volume | Select-Object Name, CapacityOn the target machine. It should tell you what the OS thinks the capacity of the drive is. If the capacity is null or 0, LM is doing what it's supposed to. If the OS says it's got a non-zero capacity, then LM is broken and you would want to take it up with support.
