Justin_Lanoue's avatar
6 months ago
vCloud Director Monitoring?
Does anyone know if there is built-in monitoring for this?
I don't see anything published and it does have an API.
Just reaching out to see if anyone here has custom build monitoring for it.
Regards,
  • Hi I have this xml file provided by LM. I have not as yet tried it but it might help you. Rename to .xml
    • Justin_Lanoue's avatar
      Justin_Lanoue
      I don't see an attached document, but LM Support also provided me a very old dev DataSource that used a deprecated API version.
      The script was a good base as I was able to rework it to use a Bearer Token instead and pull data I wanted.
      I can publish it if there is interest but it's still a WIP.
      • phakesley's avatar
        phakesley
        Would like to see your work here as having some issues with the older DS I have. I can email it as this system will not allow me to send the xml file even after renaming!
