Hi Dave,
You're correct, you may include specific OIDs that you would like to check following the <host> and separated by spaces, as in the help file you mentioned above.
You may also override the other SNNP settings using the "options" parameters before the <host>. Any parameters not specified will be pulled from the <host> Resource or the setting in the Collector Config / agent.conf settings.
agent.conf Collector Settings
https://www.logicmonitor.com/support/agent-conf-file-configurations
____
Eric Hale
Technical Support Engineer II,
LogicMonitor Technical Support
Austin, TX
Accessing LogicMonitor Support Resources
https://www.logicmonitor.com/support/about-logicmonitor/customer-support/get-support-resources
