Thanks. I guess I will dig in and see what I can find. I dont really have a platform where I can easily do that from, and personally, I like that, as a config source in the portal, I like that if I get hit by a bus, someone else can see that the script exists and is running. Having something running from some unknown place elsewhere creates its own problems, for people who inherit things. :)
I do wish that LM had a scripting platform, or a section called “Scripts” that you could just set up scheduled scripts on officially, instead of a CS workaround.
I can understand that, as a consultant I ran into that all the time where some email is coming from some system no one knows about. In the past I’ve added “fine print” to the notification emails saying that this email was generated on X server or system to help.
There are other services and packages that are more geared for centrally managing scripts or multiple systems (like RMM). I do see this particular request as kinda falling between monitoring and RMM, and can see someone thinking the monitoring system could be generating it.
