4 years agoThis is expected behavior for a datasource. Datasources can only return numerical values.
However, you could switch from a JDBC datasource to a scripted datasource (using JDBC) and use groovy to map the possible text values to integers (think error codes).
Although, it sounds like you may do better having a scripted EventSource use JDBC and check. Then you could have the eventsource check all the lines returned for any specific criteria you want and open an alert for each offending line.
