SteveBamford's avatar
SteveBamford
9 months ago
Trouble with setHTTPProxy creating discovery script.
For background I am currently working on onboarding Arista AP's that are managed from the Arista CUE platform, to build the discovery script at least I am using Groovy however when testing the Login element I am getting "setHTTPProxy MissingMethodException" the problem I have is that following the documentation presented here, I do not see what the issue is.  I have tried single and double quotes for the string of the proxy and even though the port is documented as an Integer I have even tried string to no avail.
The script is below:
*  Arista WIFI Integration with CUE for discovery of the AP's
import com.santaba.agent.groovyapi.http.*
import com.santaba.agent.groovy.utils.GroovyScriptHelper as GSH
import com.santaba.agent.AgentVersion
import java.text.DecimalFormat
import groovy.json.JsonOutput
// To run in debug mode, set to true
Boolean debug = false
// To enable logging, set to true
Boolean log = false
// Set props object based on whether or not we are running inside a netscan or debug console
def props
try {
    hostProps.get("system.hostname")
    props = hostProps
    debug = true  // set debug to true so that we can ensure we do not print sensitive properties
catch (MissingPropertyException) {
    props = netscanProps
//String key = props.get("AristaWIFI.api.key")
//String token = props.get("AristaWIFI.api.token")
//String clientId = props.get("AristaWIFI.api.clientId")
//Temp lines for testing
String key = [KEY]
String token = [token]
String clientId = "logicmonitor"
Integer collectorVersion = AgentVersion.AGENT_VERSION.toInteger()
// Bail out early if we don't have the correct minimum collector version to ensure netscan runs properly
if (collectorVersion < 32400) {
    def formattedVer = new DecimalFormat("00.000").format(collectorVersion / 1000)
    throw new Exception("Upgrade collector running netscan to 32.400 or higher to run full featured enhanced netscan. Currently running version ${formattedVer}.")
externalHost= [host dns record];
setHTTPProxy("proxy name",8080);
httpClient = HTTP.open(externalHost,443);
// Log in to arista
loginurl = "https://[Our Instance].wifi.arista.com/wifi/api/session"
payloadstring = '{}"type":"apiKeycredentials","keyId":'+key+',"keyValue":'+token+',"timeout":3600,"clientIdentifier": '+clientId+'}';
def payload = payloadstring;
def loginResponse = httpClient.post(loginurl,payload,["Content-Type":"application/json"]);
if ( !(httpClient.getStatusCode() =~ /200/) )
    // Error has occured
    println "Authentication Failure";
    return(1);
println loginResponse;
def LMDebugPrint(message) {
    if (debug) {
        println(message.toString())
Had a dive through the community and documentation and found nothing.
  • "setHTTPProxy" is an object method for the instantiated object, which in this case, the instantiated object is "httpClient".
    You need to instantiate the object first, then you can invoke methods on that instantiated object.
    The correct usage would be as follows:
    httpClient = HTTP.open(externalHost,443);   <-- instantiating the "httpClient" object
    httpClient.setHTTPProxy("proxy name",8080);   <--invoking the "setHTTPProxy" object method on the instantiated "httpClient" object
