Udayaramya's avatar
Udayaramya
1 year ago
system.properties value is not editable
In uiv4 version of portal, we are not able to edit system.properties on any of the servers.
  • That doesn’t make sense. However, just for sanity: you have scrolled to the right? (horizontal scroll bars ftw!)
    I’m also wondering if there are some LM User permission shenanigans taking place. From the screenshot that @Udayaramya shared, it looks like we should be able to see the Edit button.
  • Kwame_A's avatar
    Kwame_A
  • System Categories is now at the bottom of a resource. I have seen that system.categories isn’t listed if there are no categories. You simply add it then.
  • Ajay's avatar
    Ajay
    Hi @Udayaramya ,
    That’s right. As I mentioned you can edit only system.categories
    If you are not able to, this could be permission issue. You should raise a support ticket for these types of issues or on chat ( if available)
    Hope that helps
