Damian1's avatar
Damian1
10 months ago
SQL Server connections using mssql.<instance name>.mssql_url
For some SQL Servers due to how they are setup, we are setting the property mssql.<instance name>.mssql_url
I've noticed, when I do this, the Microsoft_SQLServer_Connections module then does not retrieve the SQL Server version and edition (e.g. Enterprise, Standard, Express), which is affecting some custom dashboards.
What's the best guidance to resolve this, would I need to create my own datasource?
  • Thank you for the helpful advice.  I've set these properties, but I think I’ll need to submit a support ticket to take a closer look as advised. I believe the issue might be affected by the fact that, for compliance reasons, we have the SQL Server Browser service disabled. So, may require some specific attention.
    • mray's avatar
      mray
      Ideally, this would all be automatic and set via the Microsoft_SQLServer_Connections PropertySource. If manually adding, you should be setting both properties.
      If you are setting both, the modules are all up-to-date, and this is still not working as expected, I'd suggest submitting a support ticket so we can take a closer look.
