grantae's avatar
4 years ago
Setting up Zoom Datasources / Propertysources
I found the Zoom Datasources / Propertysources but was unsure about what needed to be added into LM to use these, like a Microsoft Surface or <company>.zoom.us or ???
Played around with getting the zoom.api key and secret and manually added to both a Surface and a manually added <company>.zoom.us (the Propertysource uses these for the AppliesTo) but wasn't sure about the hasCategory("ZoomService") on the datasources.
I didn't get either to really work and I don't think the "device" <company>.zoom.us functioned.
Main pages I read to try to figure it out so far were:
https://marketplace.zoom.us/docs/api-reference/zoom-api
https://marketplace.zoom.us/docs/api-reference/using-zoom-apis
https://marketplace.zoom.us/docs/guides/build/jwt-app
https://www.logicmonitor.com/support/monitoring/applications-databases/zoom-monitoring
Any advice on getting these to work?
    There should be a property source in the exchange called "addCategory_ZoomService" that will get the category added for you.
  • Yeah (I have the main URLs I used for reference on the original post). I added <company>.zoom.us (our Windows team confirmed it was correct) manually and made a JWTs and got the Key and Secret, but it didn't seem like it was working. The datasources didn't match it since it didn't include the hasCategory("ZoomService"). Do I need to add that in somehow?
  • I'd be interested in knowing more about the cloud exchange stuff in regards to zoom but IDK if my company will sign off on extra spending or not.
    In the meantime I would like to try to get the Zoom datasources and propertysource working and see what it can do. (Even if it will be deprecated soon.)
    Do you have any guidance on that?
    I mean, the cloud exchange is a new feature and i thought we were letting everyone use it for free for a time until we started requiring a license for it. The traditional Zoom datasources will be deprecated at some point, so you won't be able to get support on it.
    @Brian Gladden is the product manager over that part of the tool, so I was drawing his attention to this to provide clarity.
  • Not sure what you mean by trials. I just found the data and property sources for zoom and wanted to try setting them up to see if they had useful info for my team.
  • 18 hours ago, Stuart Weenig said:
    You should look at using these through the exchange. We built new DataSources that eliminate the need to run any tasks on your collector. Simply go to Exchange >> Cloud Integrations >> Zoom >> Add and step through the wizard.
    @Brian Gladden
    When I go to Exchange (left hand bar) I do not see anything that says Cloud Integrations. I just see the modules.
    Sorry if I'm missing something.
    @Brian Gladden
