Unfortunately, i don’t have any experience with that particular tech.
However, your question isn’t “can LM do X?”. Your question is actually, “Does LM already have a module to do X?”. You’ve actually already answered that question by looking through the exchange for a module that does it finding nothing.
So your question is now, “Has anyone built a module that does this and not posted it to the exchange? If so, where could I find it?”
If the answer to that is no, your next question would be, “how would i build such a module?"
To get you started, you’d need to figure out how to get at the data in a programmatic way. How would you get that data today manually as a human? Would you log into a web UI and look at something there? Would you issue a command via SSH? Would you run a PowerShell script? The answer to that will determine how you proceed.
Also, look at JobMonitors.
