Restore removed device in Device Group
We were in process of adding 4 devices in the device group. While adding 4th device in the Logic Monitor, chose wrong device group folder. To fix the issue accidentally removed device from the group folder but after that unable to find device anywhere.
As per below article, In Step 4, I chose "Remove from the group"
Ref : https://www.logicmonitor.com/support/devices/adding-managing-devices/deleting-devices
Though when I checked for the settings > collectors > resources, its showing (3 of 4 devices) under the collector.
If I am trying to add the device again under the same collector, its giving an error that "There is another host (id=12345, displayName=xyz) with the same hostname (or IP) and monitored by the same collector.
How do I find the 4th device and add back to the right device group ?
Any help will be appreciated.
