Purnadi_KFormer Employee9 years agoSimple Check for SSL Cert Expiration Monitoring Monitoring SSL Certificate expiry days can be done in LogicMonitor by making use of datasource SSLCerts- (SSL Certificate Expiration). On the side note, SSL Certificate is used for certifying a web...Show More
Purnadi_KFormer Employee9 years ago hi Kaushal, you can use this datasource if you can add the ELB as a device.
Recent DiscussionsDo you use SSO and require group membership? And does it also assign permissions?New UI - Changes to Info tab on Resources pageNew support botMultiple 443 SSL Certificates?SolvedGet added devices from a certain month
