- Shack
Advisor
If this is a Windows device the Win32_Printer WMI class I think will tell you this. You would just need to create a new Datasource using WMI as the Collector method.
- Anonymous
Yep, looks like PrinterStatus is your property.
Is your print server a cluster? If not what are you using to pull those metrics?
