5 months ago
Monitoring interface ports on a network switch
Hi, I newbie to LogicMonitor and have been using this plafform for the last 1-2 months. We have a network switch in our platfrom that wasn’t been monitored. We setup monitoring but kept alerting o...
- 5 months ago
@acampbell78 So to verify…. You added a network switch into LogicMonitor. Standard items came back like CPU, Memory, etc… But not Network Interfaces?If that is the case, that is usually down to the access given to the specific SNMP setup you are using. Verify that the community string or your v3 setup is allowing you to pull those OIDs.
That’s possibly the case. Have you done a test of active discovery or data collection on the SNMP_Network_Interfaces DS on that device?
