4 years ago43 minutes ago, Lewis Beard said:Does it just not work?
That may very well be. I've run into some parts of the SDK that just don't do what they're supposed to.
auto.interface.ifindex is the number used to identify the interface on the device. It should be the same as the wildvalue and the [ID: blah]. It is used when polling via SNMP as it forms the last term in the OID.
The system.instanceid is the id number LM uses to identify that object in the database. This should be the ID number used in API calls.
