Thanks @Stuart Weenig, nice to hear this worked! It’s always fun to test things out (Raspberry Pi’s got a lot of cycles internally at LM!), but I would like to highlight that for monitoring production environments you will want to stick with the supported distros as outlined in our Installing Collectors document.
If problems arise with the collector we may be unable to assist in troubleshooting efforts until a supported OS version is being utilized.
If Cockpit was the driving factor to test with Fedora, it does seem that it is available for other distros we support, so maybe that might be an alternative test case you want to pursue that way you can continue using it on a supported distro if you end up liking it. Thanks!
https://cockpit-project.org/running
