1 hour ago, CaseyW said:There is currently no LogicModule for monitoring DNSSEC. I am trying to create a custom datasource using groovy in order to test DNS utilizing a dnssec key. Problem is, I don't have java/groovy experience.
I have set 3 properties on my collector device as follows: dns.resolvers: 8.8.8.8, dns.seckey: <super secret key>, dns.testname: <fqdn.com>
The only thing I really know how to do at this point is to define each of these properties at the beginning of the script as follows:
import org.xbill.DNS.*;
def dnsServers = hostProps.get('dns.resolvers');
def dnsNameToResolve = hostProps.get('dns.testname');
def dnsSecurityKey = hostProps.get('dns.seckey');Has anyone written anything for this purpose? Any ideas on what I need to do here?
I am not positive you need to store the private key to monitor, but perhaps it can help - I have not tried this myself before. You probably want to start with some examples like these (Java not Groovy, but should be fairly simple to use for Groovy development):
https://www.javatips.net/api/org.xbill.dns.dnssec.dnssecexception
https://github.com/adamfisk/DNSSEC4J/blob/master/src/main/java/org/littleshoot/dnssec4j/DnsSec.java
Certainly not usable as-is, but good ideas on how to accomplish the goal.
