Ryan_Watters's avatar
5 years ago
Flexible Netflow help
Flexible Netflow from Cisco seems overly complicated.  I was able to get Netflow going with my Palo Alto firewalls in about 5 minutes with LogicMonitor.  With my Cisco C3850 and 9300 switches, it's been a nasty struggle.  Here's what I have set up for my flow records, exporter, and monitors
flow record LogicMonitor-In
 match ipv4 destination address
 match ipv4 protocol
 match transport source-port
 match transport destination-port
 match ipv4 tos
 match interface input
 match flow direction
 match ipv4 source address
 collect interface output
 collect counter bytes long
 collect timestamp absolute first
 collect timestamp absolute last
flow record LogicMonitor-Out
 match ipv4 protocol
 match ipv4 tos
flow exporter Netflow-to-LogicMonitor
 destination <snip IP>
 transport udp 2055
 template data timeout 60
 option application-table timeout 60
flow monitor Netflow-Monitor-In
 cache timeout active 60
flow monitor Netflow-Monitor-Out
I've then used the "ip flow monitor Netflow-Monitor-In input" and "ip flow monitor Netflow-Monitor-Out output" commands on my interfaces, but I'm not getting any flows in LogicMonitor. I did some troubleshooting with the collector debug command "!netFlow func=dump <deviceid>", I think I'm seeing that I've got some mandatory fields that are missing and that's why it isn't collecting flows.  I get a return from the above command saying "msg=Miss mandatory field, both (type=14, name=OUTPUT_SNMP) or (type=10, name=INPUT_SNMP) is absent in template".  So, I think I'm missing some collect or match lines in my flow records, but trying to figure out what I need to include for OUTPUT_SNMP and INPUT_SNMP in my flow record, I'm just not having any luck.  Contacted support and they basically told me, "you'll need to figure it out on your own".  I'm assuming SOMEONE has gotten netflow working with a Cisco 3850 or 9300 before, and can just give me an idea of what they've got in their flow record.
  • Sure, I have developed internal docs on this which I exported to PDF, but of course this forum does not allow that.  Honestly, this is stuff that should be maintained in the LM documentation.  I will see if I can copy the details over to a blog post or something on our website.  In the meantime, here is the 3650/3850 section.  I believe the 9300 should be pretty similar, but I do have distinct notes for 9200 and 9500 switches.
    3650/3850
    This platform requires separate flow records for input and output.  To monitor traffic to/from the switch (e.g., for Internet flow reporting), the monitors below should be applied as input and output, respectively:
    interface GigabitEthernet2/0/11
     ip flow monitor LM-IN input
     ip flow monitor LM-OUT output
    flow exporter WM-LMW2
     destination 192.168.x.x
     transport udp 2055
     option interface-table
     option exporter-stats
     export-protocol netflow-v9
    flow record Netflow-In
     match ipv4 protocol
     match ipv4 tos
     collect counter packets long
    flow record Netflow-Out
     match interface output
     match ipv4 protocol
     match ipv4 tos
     collect interface inputflow monitor LM-IN
     exporter WM-LMW2
     cache timeout inactive 10
     record Netflow-In
    flow monitor LM-OUT
     exporter WM-LMW2
     record Netflow-Out
    3650/3850
     transport udp 2055
     match ipv4 protocol
     match ipv4 tos
     match ipv4 protocol
     match ipv4 tos
     exporter WM-LMW2
     record Netflow-In
    flow monitor LM-OUT
     exporter WM-LMW2
     record Netflow-Out
    PDF support will be coming 2022.
  • Thank you, sir! I at least don't have an angry Netflow Health header anymore.  It'll take some time before it actually starts populating graphs and such, but this is a huge step in the right direction.
