3 years ago
CSV Import Props Help
Hello, I have a list of 600+ devices to get into LM that would all have diff collectors assigned. I have all the info in a spreadsheet but when I go to the CSV import option in LM to add devices it r...
As of this moment, it’s not possible to assign different Collector’s for a single CSV Netscan, as the Collector assignment is controlled by the Netscan, and not CSV input. You would need to break up the CSV file into separate files, one for each Collector you’d want used to monitor the devices. It’d certainly be worth submitting feedback to allow Collector designation via CSV file, especially if this would be a frequent need.
In the meantime, you might consider writing a script which uses the LogicMonitor API to ingest a csv file and create resources assigned to different collectors based on the CSV details.
