Kelemvor's avatar
Kelemvor
Icon for Expert rankExpert
10 months ago
Creating a Custom Module based on OIDs?
We have some IBM MQ devices that we want to monitor.  We found some MQ items in the LM Repository, but those are for monitoring the MQ application.  We also need to monitor the device for CPU and Memory.
I was given the following information and told we should see about monitoring them.  I'm not sure if I can modify something to get started or if we'd have to create something from scratch.  I'm not familiar with creating anything like this and am hoping someone can point me to something similar I can use and modify or or figure out how to create this from scratch.
Below are the numeric OID and their respective full details - It shows the CPU usage and also at last 3 different intervals 1 min 5 min and 15 min
.1.3.6.1.4.1.14685.4.1.521.1.0 = Gauge32: 2 %
.1.3.6.1.4.1.14685.4.1.521.2.0 = STRING: 0.14 %
.1.3.6.1.4.1.14685.4.1.521.3.0 = STRING: 0.31 %
.1.3.6.1.4.1.14685.4.1.521.4.0 = STRING: 0.34 %
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusSystemCpuStatusCpuUsage.0 = Gauge32: 3 %
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusSystemCpuStatusCpuLoadAvg1.0 = STRING: 0.27 %
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusSystemCpuStatusCpuLoadAvg5.0 = STRING: 0.34 %
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusSystemCpuStatusCpuLoadAvg15.0 = STRING: 0.34 %
And below Filesystem Monitors - Can we set alerts if the Free is less than 50% of Total for all three different readings  - Total encrypted/Free encryptes - Total temp/Free Temp - Total Internal/Free Internal
.1.3.6.1.4.1.14685.4.1.29.1.0 = Gauge32: 23223 Mbytes
.1.3.6.1.4.1.14685.4.1.29.2.0 = Gauge32: 29857 Mbytes
.1.3.6.1.4.1.14685.4.1.29.5.0 = Gauge32: 4036 Mbytes
.1.3.6.1.4.1.14685.4.1.29.6.0 = Gauge32: 4096 Mbytes
.1.3.6.1.4.1.14685.4.1.29.7.0 = Gauge32: 3071 Mbytes
.1.3.6.1.4.1.14685.4.1.29.8.0 = Gauge32: 3072 Mbytes
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusFilesystemStatusFreeEncrypted.0 = Gauge32: 23223 Mbytes
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusFilesystemStatusTotalEncrypted.0 = Gauge32: 29857 Mbytes
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusFilesystemStatusFreeTemporary.0 = Gauge32: 4036 Mbytes
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusFilesystemStatusTotalTemporary.0 = Gauge32: 4096 Mbytes
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusFilesystemStatusFreeInternal.0 = Gauge32: 3071 Mbytes
IBM-MQ-APPLIANCE-STATUS-MIB::mqStatusFilesystemStatusTotalInternal.0 = Gauge32: 3072 Mbytes
    • Kelemvor's avatar
      Kelemvor
      When I click those links they take me to a n Academy login screen.  I fill it out and I end up in my company's LM portal.  I went to Training in there and it said it'd send me an email, but I never received anything.  Hmm.
      • mray's avatar
        mray
        If you did not receive the email:
        1. Confirm your company email rules have whitelisted these domains:
          • logicmonitor.skilljar.com
          • alerter@<portalsubdomain>.logicmonitor.com
        2. Confirm the emails are not being filtered – search "Training Account Verification" and check spam/junk folders
        Also note that you have to open the verification link within the same browser session that you have your LM portal open and with the same user logged in.
  • Happy to jump on a quick Teams meeting to get this done - should be a quick one.  DM me for availability!
  • You may want to look for the "Anatomy of a DataSource: SNMP" video on the LM Academy. If I remember correctly it does cover the process of creating custom SNMP-based DataSources. It likely uses the old Interface though, so it may look a bit different in the actual portal.
    You can also look at just about any Datasource that uses the SNMP collection method, like for example "snmpTCPUDP". Some of them use a Script collection method which you can also try but unless you know groovy scripting, I would stick with SNMP collection as it's a bit easier and based on the info above, I don't think you need to get fancy with scripts.
    Note that you will only need to use the OID numbers and not the MIB "BM-MQ-APPLIANCE-STATUS" stuff.
