1 Reply
If you are getting an "Index 0 out of bounds" error for Meraki water sensors you can update the code to account for empty lists rather than crashing as it does currently.
* © 2007-2024 - LogicMonitor, Inc. All rights reserved.
******************************************************************************/import com.santaba.agent.groovy.utils.GroovyScriptHelper as GSH
import groovy.json.JsonSlurperString organization = hostProps.get("meraki.api.org")
String serial = hostProps.get("auto.endpoint.serial_number", hostProps.get("meraki.serial"))
if (!organization) {
println "Organization ID missing; device property meraki.api.org must be set."
return 1
if (!serial) {
println "Serial missing; device property auto.endpoint.serial_number or meraki.serial must be set."
return 1
}def debug = false
def log = false
def logCacheContext = "${organization}::cisco-meraki-cloud"def modLoader = GSH.getInstance(GroovySystem.version).getScript("Snippets", Snippets.getLoader()).withBinding(getBinding())
def emit = modLoader.load("lm.emit", "0")
def bab = modLoader.load("lm.bitsandbobs", "0")
def lmDebugSnip = modLoader.load("lm.debug", "1")
def lmDebug = lmDebugSnip.debugSnippetFactory(out, debug, log, logCacheContext)
def cacheSnip = modLoader.load("lm.cache", "0")
def cache = cacheSnip.cacheSnippetFactory(lmDebug, logCacheContext)def cachedOrganizationDeviceStatuses = cache.cacheGet("${organization}::organizationDeviceStatuses")
if (cachedOrganizationDeviceStatuses) {
if (debug) println "Fetched cached data using key ${organization}::organizationDeviceStatuses..."
def organizationDeviceStatuses = new JsonSlurper().parseText(cachedOrganizationDeviceStatuses)
def organizationDeviceStatus = organizationDeviceStatuses?.values().find { it.serial == serial }
def statusCodes = ["online": 0, "dormant": 1, "offline": 2]
def data = statusCodes.get(organizationDeviceStatus?.get("status"), 1)?.toInteger()
emit.dp("status", data)
}def cachedOrganizationSensors = cache.cacheGet("${organization}::sensors")
if (cachedOrganizationSensors) {
if (debug) println "Fetched cached data using key ${organization}::sensors..."
def organizationSensors = new JsonSlurper().parseText(cachedOrganizationSensors)
def organizationSensor = organizationSensors?.find { it.serial == serial }
def sensorReadings = organizationSensor?.get("readings")if (sensorReadings?.battery?.percentage && sensorReadings.battery.percentage.size() > 0) {
emit.dp("battery", sensorReadings.battery.percentage.get(0))
} else {
println "Battery percentage data missing or empty"
}if (sensorReadings?.water?.present && sensorReadings.water.present.size() > 0) {
emit.dp("water", sensorReadings.water.present.get(0).toString() == "false" ? 0 : 1)
} else {
println "Water presence data missing or empty"
}bab.keepAlive(hostProps)
return 0
