Patrick_Rouse
Product Manager
3 years agoOur new Cisco Catalyst SD-WAN modules are now generally available and the product docs are here:
https://www.logicmonitor.com/support/cisco-catalyst-sd-wan-monitoring
Our previous Cisco vManage modules only supported up to version 20.4 and used an API that Cisco does not support for continual performance monitoring. So, these support the latest versions of Catalyst SD-WAN 20.6.3 and higher and use the Cisco recommended SD-WAN Bulk API.
