@Michael Baker Thanks for sharing your insights. I would need this working for Fortigate and Cisco IOS XE devices. If you follow the above approach, you will at least have issues with the OID 1.3.6.1.2.1.15.3.1.7 when having multiple neighbors with the same IP, since the OID will only return one value.
@Patrick Rouse Thanks, I will consider creating a feature request.
