On 2/1/2022 at 5:13 PM, Stuart Weenig said:Yes, many of the SSH datasources available out of the box provide superior monitoring and detail vs. the SNMP data that is pollable.
Almost. There's more SNMP monitoring that happens on Linux than Windows, because Windows has WMI that, like SSH, provides richer monitoring data.
Also, just because you enable SSH monitoring, doesn't mean you're necessarily disabling SNMP monitoring. Do both.
Hi Stuart
Thanks for your insight :)/emoticons/smile@2x.png 2x" title=":)" width="20" />
I think we will wait with the SSH monitoring, we have a lot of machines where we disable SSH as a security measure and only enabled it during maintenance.
We want to try go the OpenMetrics way instead :)/emoticons/smile@2x.png 2x" title=":)" width="20" />
