mhashemi's avatar
8 years ago
API call for collector versions
Please add an API method that will report the current collector version. This will help us to programmatically determine and report on how many collectors are not running the current version.
  • Sarah_Terry's avatar
    Sarah_Terry
    @mhashemi the GET /setting/collectors operation will already return the version for each Collector in the response (via the 'build' field). Is this sufficient for your use case?
  • @Sarah Terry, I must have missed the notification for your reply. To clarify, I was referring to a list of released collector versions, not the version installed on a particular collector. It appears that the requested functionality will be released (and documented) eventually. Thanks.
