manthena2020's avatar
2 years ago
Reading custom data sources error Messages
Hi please find the below code
import groovy.sql.Sql
import java.sql.SQLException
// Register the Sybase driver
Class.forName("com.sybase.jdbc4.jdbc.SybDriver")
// Get basic info to connect
def hostname = hostProps.get("system.hostname")
def user = hostProps.get("sybase.user")
def pass = hostProps.get("sybase.pass")
def port = 21000
def wildvalue = instanceProps.get("wildvalue")
def url = "jdbc:sybase:Tds:" + hostname + ":21000"
def driver = "com.sybase.jdbc4.jdbc.SybDriver"
def sql = Sql.newInstance(url, user, pass, driver)
// Check Sybase server status
try {
sql.getConnection()
println("status:0") // Server is online
} catch (SQLException e) {
if (e.getMessage().contains("Login failed")) {
println("status:1") // Invalid password or login failed
} else {
println("status:2") // Other connection or server error, including server offline
} finally {
sql.close()
when i run this code . iam getting status 0 as my output. i want to test how this script works for login failed. i have tried this code with wrong credentials then it is not printing any thing its showing error message
code:
The script failed, elapsed time: 0 seconds - JZ00L: Login failed.  Examine the SQLWarnings chained to this exception for the reason(s).java.sql.SQLException: JZ00L: Login failed.  Examine the SQLWarnings chained to this exception for the reason(s).	at com.sybase.jdbc4.jdbc.ErrorMessage.raiseError(ErrorMessage.java:775)	at com.sybase.jdbc4.tds.Tds.processLoginAckToken(Tds.java:5382)	at com.sybase.jdbc4.tds.Tds.doLogin(Tds.java:725)	at com.sybase.jdbc4.tds.Tds.login(Tds.java:579)	at com.sybase.jdbc4.jdbc.SybConnection.tryLogin(SybConnection.java:422)	at com.sybase.jdbc4.jdbc.SybConnection.handleHAFailover(SybConnection.java:3335)	at com.sybase.jdbc4.jdbc.SybConnection.<init>(SybConnection.java:348)	at com.sybase.jdbc4.jdbc.SybConnection.<init>(SybConnection.java:253)	at com.sybase.jdbc4.jdbc.SybDriver.connect(SybDriver.java:232)	at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:677)	at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:228)	at groovy.sql.Sql.newInstance(Sql.java:422)	at groovy.sql.Sql.newInstance(Sql.java:466)	at groovy.sql.Sql$newInstance.call(Unknown Source)	at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:47)	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:152)	at Script272.run(Script272.groovy:16)
so please help to how to avoid the error mesage and print status 2
    Please insert code blocks using the code block option in the toolbar.
    You should be setting the return code in a variable in your try/catch/finally block and returning that error code. Then you can just have a datapoint that looks at the return code. That also solves the problem of your current code not having a return code, which will cause LM to ignore the output.
    return_code = 0
    try {
    sql.getConnection()
    return_code = 1 // Invalid password or login failed
    } else {
    return_code = 2 // Other connection or server error, including server offline
    } finally {
    sql.close()
    return return_code
    No need for a print statement unless you have something other than the return code you want to return.
    The toolbar is right above the text you’re typing. It has bold, italic, underline, etc. On the right, there are three dots and that has a code widget you can insert.
  • import groovy.sql.Sql
    def port = 21000
    return_code = 0
    try {
    sql.getConnection()
    } else {
    } finally {
    sql.close()
    return return_code
    i am getting 0 , even for Login failed as well as. Please look into it
    The only thing I can guess is that when groovy tries the sql.getConnection(), it’s resolving to true even if login fails. You’ll need to figure out something additional that determines if login was successful or not.
Recent Discussions
