WMI Groovy Batch Script Group Processes by Instances
Has anyone ever tried to group processes over instances so we can populate the data in Table with instance as a column.
@Stuart Weenig any idea?
Ashish Sikarwar
5 comments
·2 years agoRelated, but not the one i was thinking of:
https://community.logicmonitor.com/product-discussions-22/table-style-widget-values-from-propertsource-possible-4074LM User
·2 years agoOh, i see. No that’s not possible. Very popular feature request though. Actually it came up recently and there was some verbiage in a recent community post that could be copied/pasted into the feature request system to request it again. Let me see if i can find it...
Ashish Sikarwar
OP2 years agoYes for example process data can be populated like this. I have to concatenate instance name & VM Name Ex: ##INSTANCE##_##RESOURCENAME##
I was wondering if we can have discreet columns for Instance and VM so data points can be sorted either by instance or VM (in case there are multiple VMs) … currently as a workaround I put instance name first, so it can be sorted alphabetically by instance.
·2 years agoNot sure i follow. The table widget shows one row per instance. Instance is not a string, it’s an instance object.
Ashish Sikarwar
OP2 years agoEssentially, I was thinking if there is a way to include instance as column however I realized then that it has to be used as a data point but instance is a string, is there any other way we can display data in table with instance as as its own column
