Remote DB connections via Oracle SQLnet
While Logic Monitor seems determined that it needs to "connect" to a remote host to gather data, in the case of Oracle DB up / down testing it's much easier to just perform a remote connection via SQLnet.
Has anyone been able to build remote database login calls from the collectors?
We created Groovy script from a bash script to connect on the Collector via Oracle SQLnet but haven't been able to integrate that into the Collector server. The idea being - we'll add these scripts for each database on each server using or Oracle LDAP DB names which resolve fine in our SQLnet script. Do a simple connect - verify and return OK/ not OK.
This will help us resolve the issues with Logic Monitor failing to understand Oracle RAC and PDB databases.
Ben
casteeb
OP2 years agoStuart, this solution works, we have it implemented now and I just want to thank you for your help.
Ben
·2 years agoTotally welcome.
casteeb
OP2 years agoStuart, sorry I haven't had time to roll back to this. We are actively working with LM support to get this implemented. Once we have the algorithm implemented and working, I'll update again on how it worked out.
Appreciate your input.
casteeb
OP2 years agoOddly in this case I want to manually add/remove the DB names in a list on each server, so maintaining 1 list on each server should work for us. The auto discovery for Oracle RAC and PDBs in LM is sort of the reason we got here. lol
That's not really a problem for use because adding / removing a database requires about 25 Tasks to different functional areas in the data center.
·2 years agoThen in that case, I'd go with this discovery script:
And put the list on each server with the oracle_rac_dbs property. Comma separate each db/display name pair and separate the db name from the display name with a pipe character.
That takes care of your discovery. Does your collection script test one DB at a time or all DBs on a server?
casteeb
OP2 years agoThanks Stuart, we worked on implementing this yesterday. Found a lot of good scripting examples in the built-in Oracle code.
Added the DB list to the server, added a simple check_oracle Datasource script to the My Module Toolbox on the collector which just echos the list and returns 0 , in check_oracle DS script we set AppliesTo (checked with Launch IDE and validated that resolves to the specific server server name and IP where we put the list). But that Data source is still stuck on the "Not in use" status. I'm missing something ....
·2 years agoYou should have one DS with two scripts. If you have a script to automatically discover the list of database names (check_oracle), that seems like it would be your discovery script. Then your collection script would actually check to see that each instance discovered in your discovery script can be connected to.
·2 years agoOk, so you need it to run on the collector. If you're not running it in the collector debug now, how are you running it? Groovy installed on your laptop? Are there custom libraries you've installed on your laptop that you're importing into the script? If so, you'd need to install those jar files on the collector. Mike_Aracic could probably point you to docs on how to do that.
casteeb
OP2 years agoYeah, that's the problem, we added the script using the LM Collector GUI, associated it to that server, the script shows up as valid but not associated to run on any host. We are new to LM and still learning how it works. If we could execute it, the rest I think we can figure out.
I did try to pre-test the script with Groovy on the Collector server, but while LM affirms that it can run Groovy scripts, that executable is not available system wide, not in the user environment. I'm hesitant to add another install of Groovy because I don't want to risk a library clash with LM itself. The sqlnet client and LDAP binaries have all been tested on the server and connect fine to any valid database name.
If we can just get the script to run and raise some errors, we'd have something the move forward with..
·2 years agoIf your new datasource isn't applying to any devices, you might consider checking the AppliesTo expression. But have you considered how your instances will get created? Discovery? Batchscript vs. script?
casteeb
OP2 years agoIn Nagios this was very simple, when we built new Oracle RAC DBs for the clients, we just added the DB name to the server config in Nagios and called our check-oracle.sh script with it. The script returns 0 or 1 plus the output from the connect attempt. This showed up in Nagios as up / down and if down the message Oracle Sqlnet returned - (commonly No listener found , if the DBA started the DB and forgot to start the listener). Our Oracle LDAP manages the connection string, and the port is open to the Nagios servers. I'd just like to replicate that functionality. Very easy.
·2 years agoThat's pretty much what you can get to in LM, but your setup is a little more complicated. More powerful tools require more to set up properly. Once you get it setup properly, it would be as easy as adding the db name to the instance list property.
Your next step is to think about whether you would do batchscript or script. This depends on how your collection script does or will work. Does the script run once and return the data for one db? Or can it run once and return the status for all the DBs. Probably the former, in which case you'd land on a script (not batchscript) type datasource.
The next is to determine the input parameters needed for your collection script. Probably the db_name and maybe some credentials, yes? Your collection script would pull in the db name from the wildvalue or wildalias (which we'll set when we talk about discovery) using `hostProps.get("wildvalue")` or `hostProps.get("wildalias")`. You can pull in the credentials using the `hostProps.get("propname")` method, `hostProps.get("jdbc.oracle.user")` for example. You might also have properties for the port number and any other parts of the connection string. The target server could be fetched using `hostProps.get("system.hostname")`. You need to make sure your collection script can pull the inputs dynamically at runtime.
For discovery, you should at least give a passing thought to whether the db names could be discovered programmatically. Does the list of DB names exist already? Could LM pull that list from there? If so, write a script to do it.
If not, you'll store the list as a property in LM on the device. Then your discovery script would pull from that property to create the instances in LM. This is the property you would update every time you have a new db name you want to add to the list. Each instance would, under the best circumstances, have both an identifier and a display name. They can be the same, but often the display name looks better if it's human readable.
Let's say you had 3 databases: sales, marketing, and customers. You would create a property that you might call "oracle_rac_dbs" and give it value of "sales,marketing,customers". You'd create this property on the server where the DBs exist and where you can query to get the status of each. You could then use a simple script to interpret the property list and create each instance in LM under the device like this:
The first line does three things:
The println statement tells LM to create an instances where the wildvalue is the individual string and the wildalias is the individual string.
This would result in the following instances:
However, it woud probably be better to give better display names (wildaliases) to your instances. To do this, we'd simply embed the display name in the list stored in the property: "sales|Sales,Marketing|Direct Marketing,customers|CRM".
We'd adjust our discovery script to look like this:
The first line does the same thing as before. The second line splits each instance string into two along the pipe (|) character and stores the results in wildvalue and wildalias, respectively. The next line outputs the data to LM in the format required to build the instances. This would result in instances that look like this:
The nice thing about using a property for discovery is that it dictates your AppliesTo. If the property exists, monitor it; if it doesn't, don't. In this case, I'd set the AppliesTo to simply be "oracle_rac_dbs". That tells LM to apply the datasource only to servers that have the property (the servers you added the property to).
Once you have your instance creation sorted, you plug in your collection script, which pulls the wildvalue to use as the principal input for your collection script. The collection script then connects to the db, returns a 0 or a 1 (as the return value of the script would be easiest). Then you setup a datapoint to read the return value of the script as a datapoint.
Once you get it all setup, your workflow would be like this:
When we built new Oracle RAC DBs for the clients, we just added the DB name to the oracle_rac_dbs property on the device in LM which calls our collection script with it. The script returns 0 or 1.
casteeb
OP2 years agoLM User
·2 years agoWhat do you mean by
Have you built built the collection script? Does it run from the collector debug? Does it output in LM's prescribed output format? That is putting the cart before the horse since you would need to know script or batchscript. That will depend on discovery. Have you figured out how you're going to get instances into LM (manually or automatically)? I assume it would be multi-instance since you might have multiple DBs per resource in LM.
