LogUsage data source
We are having all our devices sending syslog to LM collector. Via LogUsage data source, we can monitor if the device sends syslog data or no. But the threshold to alarm on that is only 60 minutes.
We would like to make the threshold longer like 1 or 2 days because some devices are quieter than others, and we want to control if we missed to configure syslog on one of the devices or it doesn't send syslog anymore due to any reason.
So, i contacted LM support, they said it would be custom datasource. Any help with how to achieve that?
omarhegazy
4 comments
omarhegazy
OPUnfortunately that didn't work because when i test to stop the device from sending any syslog to the collector, the LogUsage will show just nothing, and thus can't tune alert on 0 value or No Data value.
See here i stopped it on 14:10, and nothing is reported afterwards
omarhegazy
OPThanks for your feedback.. i will test that and see if it works.. will let you know :)
Justin Lanoue
Your best built-in option is to create an alert rule that auto-escalates every 1440 minutes targeting the LogUsage datasource.
You would then target the alert rule to that does nothing on Stage 1 and Stage 2 and then on Stage 3 creates your a ticket.
Let me know if that works for you :)
Justin Lanoue
ou would then target the alert rule to an escalation chain* that does nothing on Stage 1 and Stage 2 and then on Stage 3 creates your a ticket.
