LogicMonitor Portal Security
These articles:
- https://techcrunch.com/2023/08/31/logicmonitor-customers-hit-by-hackers-because-of-default-passwords/?guccounter=1
- https://www.bleepingcomputer.com/news/security/logicmonitor-customers-hacked-in-reported-ransomware-attacks/
...indicate that some LogicMonitor accounts may have had weak default passwords applied and become compromised.
Until we have an official word from LogicMonitor, may I suggest that all LogicMonitor administrators:
- Delete or suspend any users that should not be in your system
- Ensure that no “out of the box” accounts are Active (including the lmsupport account)
- You should set this account to “Suspended” until we have word that this account is not affected
- Note that unless this account is Active, LogicMonitor Support cannot access your portal
- Enable 2FA for ALL users
- I mean, you did that already, right? RIGHT?
- IMPORTANT: You need to do this for administrator users, even if you have SSO
- Ensure that any user that has not logged in recently (say for 60 days) is either deleted or set to Suspended
- IMPORTANT: Revoke administrator/manager rights from anyone that does not absolutely need them
- The recommendation is 2 users per LogicMonitor portal
- If you don’t recognise a user, seriously consider setting it to Suspended
- Be cautious of System Integration accounts - you may disrupt these if you are not careful
- If a system has access, ensure that this via an API user, not an Access Token on a named person.
I will update this post with other suggestions as they are made.
David Bond
8 comments
Some additional information on how to keep your LogicMonitor portals secure, including the 2FA authentication enablement. LogicMonitor Security Best Practices, 2FA FAQ’s & User Reports.
@David Bond @Stuart Weenig thank you for sharing this level of detail! Much appreciated!
Kwame Armstrong
·2 years agoFor those frantically enabling 2FA everywhere, I can recommend the Authy app, which is low-support, even if you are an MSP with a lot of users.
Users will need to add the Authy app to their Android / iPhone first, after which the “Verify using OneTouch Verification (Authy app)” option is quick and painless:
Authy is good stuff
David Bond
OP2 years agoThanks @A11ey - we really appreciate you providing the “official” word 🙂. Marked as Best Answer.
We can confirm that LogicMonitor is currently investigating a security incident that affected a small number of customers, and we are taking all necessary and recommended steps to mitigate any impact. All known affected customers have already been notified, and we are working with these customers to take preventative measures. We recommend all customers take the time to secure their accounts with the already available feature sets available in customer portals, such as mandating 2FA. Here is the Two-Factor Authentication Setup Guide.
If you aren’t familiar with the configuration of these settings, we will be happy to connect you to support for further assistance
David Bond
OP2 years agoFor those frantically enabling 2FA everywhere, I can recommend the Authy app, which is low-support, even if you are an MSP with a lot of users.
·2 years agoFull Disclosure: I am not an LogicMonitor employee, but was in the past.
One more to add:
When I started at LM over 4 years ago, the default at that time was a temporary password that was already not what is mentioned in those articles. Also, that temporary password was only usable once as it required you to change the password as soon as you used it. Reading several articles last night and this morning, most of them are wildly and factually incorrect. LM does not create user accounts for you, that’s up to you as the LM admin. It’s possible you contracted LM Pro Services to do this setup, in which case, it’s possible one single person in Pro Services was still creating user accounts with the old (pre 2019 at least) style of default password. However, my experience with the engineers in that group leads me to believe that none of them would be that careless.
Take statements in those articles like “until recently” and “they define all user accounts for your org” with a VW bug sized grain of salt. Remember, “news” outlets like that are not interested in peddling the truth, they are interested in getting view counts. If you ever think that a news article is there to provide you with useful information, you have been duped; you are the product.
Some questions I’ve been getting last night and today:
“Just confirming we change default passwords on the collectors?” - This is not actually the password that the articles claim was compromised and is not a credential set or created by LM. The Collector is installed on either a Windows or Linux password provided by the customer. The Collector runs as a service using either an account created on the OS for the purpose of running the Collector or it runs as LOCALSYSTEM (an option on Windows). LOCALSYSTEM obviously runs as the system itself so it doesn’t have credentials associated with it. If desired, you can create an account, either local to the system or in a domain, that the Collector runs as. In the case of Linux, the Collector installer has for some time prompted you for the name of an account to use or create, defaulting to creating the “logicmonitor” user, which is created and given the proper permissions to run the Collector daemon.
“What about the password for the logicmonitor user created during Linux Collector installation?” - That’s a good question, but an easy one to answer. When running
sudo passwd --status logicmonitor, you should see an output that looks like this:logicmonitor L 01/26/2023 0 99999 7 -1The second field of this output should read “L”, meaning this is a locked password. From the passwd man page:
This means that the account is created without a password option available, essentially cutting off that option as an attack surface.
“Are we impacted?” - Most likely not, this was reportedly a small subset of customers and in no way a “large hacking operation”. We are not impacted because we force SSO for the employees here at this MSP and we define random default passwords for all customer user accounts, with 2FA enforced and requiring the reset of the password on first login.
“What about the lmsupport account?” - This account is used by engineers in LM support to log into your portal and assist you when you contact them for assistance. The method for an LM employee to use this account is RBAC controlled within LogicMonitor (not any LM employee can use it) and requires two factor authentication by the LM engineer (unless it has changed, which is unlikely). Under normal circumstances, we have this account restricted to a read only account, to minimize that attack angle as well. When a support case is opened, if the engineer needs admin access to do something, they can request that we temporarily change the role of that account to a higher level role so they can do what they need to do to help us.
David Bond
OP2 years agoUPDATE: I have had confirmation this morning from LM Support that:
I would discourage any speculation until LogicMonitor have made a statement. However do not delay in securing your accounts, with my list above a good starting point.
Again, I’m willing to update the advice, but am awaiting LogicMonitor’s public statement before doing so.
